[Me...] Posted December 21, 2018 Share Posted December 21, 2018 I have the system error message when try to set the stylus system to the automatic stylus system change. The below is the error message appear at the box: Please let me know how I can clear the error for the issue. I appreciate the help. SYSTEM STATE Calypso Inspection: Measurement Plan 9 Creation software version: 5.4.0800 Date and time: #(21 December 2018 13:37:34) Actual characteristic: 2 Point Diameter 2 Point Diameter1:::::::::::::::::::::::::::::::::: Actual feature: Cylinder Cylinder Ø6.693..................................... Creation DME: MMZ_B Hostname: Zeiss-HP Mancnc active: false Navi mode: automatic Run mode: manuel OS Windows 7 Professional win32 V6.1 nt i386 ucs2 CMMOS Actual configuration: 10D-600L Actual stylus: 10 mm -Z ID chain CS: _VAST,__VAST ncDisplayStatus: 22-----#-------- SDO version: 3.10.6.7 Sensor: VAST TCO pending: 0 OBJECT OrderedCollection () firstIndex->1 lastIndex->0 METHODSTACK Unhandled exception: this collection is empty OrderedCollection(Object)>>error: OrderedCollection(Collection)>>emptyCollectionError OrderedCollection(Collection)>>emptyCheck OrderedCollection>>last optimized [] in [] in Zeiss.Calypso.ESProbeSelect>>initialize Zeiss.Calypso.ESProbeDictionary(Dictionary)>>do: optimized [] in Zeiss.Calypso.ESProbeSelect>>initialize True>>ifTrue:ifFalse: Zeiss.Calypso.ESProbeSelect>>initialize Zeiss.Calypso.ESProbeSelect class>>initWithMode: Zeiss.Calypso.ESProbeSelect class>>selectProbeConfNameAndCreateInfo:dataStore: Zeiss.CMMOS.OMProbeChangerUI>>setConfToChanger Zeiss.CMMOS.OMProbeChangerUI>>aspectChanger DependencyTransformer>>update:with:from: DependentsCollection>>update:with:from: ValueHolder(Object)>>changed:with: ValueHolder(Object)>>changed: ValueHolder(ValueModel)>>value: WinXPMenuButtonController(MenuButtonController)>>dispatchMenuSymbol: WinXPMenuButtonController(MenuButtonController)>>dispatchMenuSelection: optimized [] in MenuButtonController>>pullDownAction BlockClosure>>ensure: WinXPMenuButtonController(MenuButtonController)>>pullDownAction WinXPMenuButtonController(MenuButtonController)>>redButtonPressedEvent: WinXPMenuButtonController(Controller)>>doubleClickEvent: DoubleClickEvent>>dispatchTo: WinXPMenuButtonController(Controller)>>handleEvent: EventDispatcher>>dispatch:to: EventDispatcher>>dispatchEvent: DoubleClickEvent(Event)>>dispatch DoubleClickEvent(Event)>>dispatchForWindowManager: optimized [] in WindowManager>>safelyDispatchForWindowManager: BlockClosure>>on:do: WindowManager>>safelyDispatchForWindowManager: WindowManager>>processNextEvent optimized [] in [] in WindowManager>>newProcess BlockClosure>>on:do: optimized [] in WindowManager>>newProcess BlockClosure>>on:do: optimized [] in Process class>>forBlock:priority: #endOfMessage# Link to comment Share on other sites More sharing options...
