[Mi...] Posted May 31, 2018 Share Posted May 31, 2018 Is there a way in PiWeb to access and report the Form Factor (S) and Styli radius (R) using the Probing System Qualification Characteristic? My goal is to make it easier to track the results over time. ❓ 😎 Link to comment Share on other sites More sharing options...
[Mi...] Posted May 31, 2018 Share Posted May 31, 2018 Yes. I do that here when I calibrate probes. I have it set up in the PRG to report out the dev and rad. Piweb takes that info and shoots out my reports. I can track the probes from the initial start up . I use formulas in Calypso and PiWeb runs with them. I can go into more detail if needed. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 18, 2018 Share Posted October 18, 2018 Anyone have an idea why I get an internal error with this code? See attached image getProbe("#1 Cx1.0","1MM").radius/25.4 Internal error PCMReferenceWithChild.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted October 18, 2018 Share Posted October 18, 2018 Well, I thought that was the problem, now I don't know what is. Link to comment Share on other sites More sharing options...
[Sh...] Posted October 20, 2018 Share Posted October 20, 2018 Try removing the # sign from your probe name. Special characters cause lots of problems with probe names, especially if you import names. You can make a copy of the probe to test it first. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 22, 2018 Share Posted October 22, 2018 I found the problem. For some odd reason, when I changed the name of a characteristic with a formula, it change the name in formula's of other characteristics tied to the same Probe name. Original Characteristic: 1MM Formula: getProbe("#1 Cx1.0","1MM").stdProbeDev/25.4 Renamed characteristic: 1MM stdProbeDev Formula: getProbe("#1 Cx1.0","1MM stdProbeDev").stdProbeDev/25.4 The string "stdProbeDev" was being added to my formula's. I think this is a bug? I use "getProbe" I am not recalling the characteristic by name Changing the name of the characteristic changes the name in my formula This 100% affected single tip styli in the Z axis (Gets interesting here) On star configurations, and only some star probes, the Z axis tip name in the formula was changed Link to comment Share on other sites More sharing options...
[An...] Posted December 17, 2018 Share Posted December 17, 2018 Hi. I'am very new to PCM, could some one please post the code for getting x,y and z axis from Result element as well? so that I can monitor this values in piweb. Thanks in advance. Link to comment Share on other sites More sharing options...
[Pe...] Posted December 17, 2018 Share Posted December 17, 2018 getProbe("StylusName","stylusSystemName").probeVector.x getProbe("StylusName","stylusSystemName").probeVector.y getProbe("StylusName","stylusSystemName").probeVector.z Link to comment Share on other sites More sharing options...
[To...] Posted December 17, 2018 Share Posted December 17, 2018 Please sign in to view this quote. Peter, I believe you have the order reversed, The first item is the stylus name and the 2nd item is the stylus system name. Link to comment Share on other sites More sharing options...
[Pe...] Posted December 18, 2018 Share Posted December 18, 2018 Doh! Thanks, Tom. Link to comment Share on other sites More sharing options...
[An...] Posted December 19, 2018 Share Posted December 19, 2018 thank you so much, it worked! I have tried to find PCM commands in a course compendium on PCM from Zeiss. but it was not much help, as it was virtually the same as the help file found in Calypso. Does some of you have any tips on where to find an overview of these commands. Regards Andreas. Link to comment Share on other sites More sharing options...
