Cook Book Outlier Plane Evoluation
Hello. Can you please advise me where should I copy this parameters for me flatness check. ? Where is cutoff wavelength, pre-filter, and sigma. Is this OK ? ? ?
That setting you're showing is not the same thing as the cutoff. The setting at the bottom should be 0 - 10mm as described in the Pre-Filter settings.
The 0.025, 0.8, 2.5mm etc. settings is on the previous screen under "Filter". The window you're showing is "Outliers".
Iteration 1 is default, but you can try more. As I can say, the more are sometimes the better. My standard is 4 because there are always some nasty single points the regular filters can't kill without losing too many points.
Iteration means how often it repeats the other filters. (It works like a lawn mower that drives the same track over and over 🤣 )
I believe the filters are applied only after the outlier elimination process is completed. I also believe the iterations are only processing the outlier elimination. And, the use of the proper pre-filter settings is key to eliminate the effects of poor form . Without the correct pre-filter settings, outlier elimination has a tendency to remove too many good points. If I have mis-stated something, I am open for correction.
