Cad Model not matching assigned alignment
You can fix it by going to Cad Model Transformation and move/rotate the model until it matches your Base Alignment. You can extract features or take points from the CAD model, note their position, and use that information to transform the model to where you want it. Then just delete the features you extracted.
I remember earlier versions of Calypso having an issue's with models coming in as metric and that posed an issue if you we're working in inches. I believe it was like in version 5.0 to 5.4.
