[Me...] Posted November 8, 2018 Share Posted November 8, 2018 Having issues loading Autorun... Capture.PNGFetching info... Link to comment Share on other sites More sharing options...
[Me...] Posted November 8, 2018 Author Share Posted November 8, 2018 Also having this issue when trying to add a new program to Autorun: Capture1.PNGFetching info... Link to comment Share on other sites More sharing options...
[Me...] Posted December 12, 2018 Author Share Posted December 12, 2018 Any luck figuring this out? Having the same error in AutoRun. Link to comment Share on other sites More sharing options...
[No...] Posted December 13, 2018 Share Posted December 13, 2018 Are you using a shortcut to navigate to the measurement plan directory? Just an idea, because Autorun doesn't like shortcuts. Amendment: Our shortcuts contain network paths, so I guess this is the cause, not the shortcut itself. See below. Link to comment Share on other sites More sharing options...
[Da...] Posted December 13, 2018 Share Posted December 13, 2018 Do you have your programs on network drive ? Link to comment Share on other sites More sharing options...
[Br...] Posted December 13, 2018 Share Posted December 13, 2018 I've noticed lately Autorun does not like network file paths. Link to comment Share on other sites More sharing options...
[Me...] Posted December 13, 2018 Author Share Posted December 13, 2018 I believe it was a combination of the setup of the default files and our Network refreshing and being super slow. Whoever set up our machine did not setup the default program location in the correct folder on our Network. I've definitely noticed that Autorun does not seem to work well on the network though. Link to comment Share on other sites More sharing options...
[No...] Posted December 13, 2018 Share Posted December 13, 2018 Calypso as a whole doesn't like network paths, especially the server double backslash "\\". But don't despair, I believe there's a patch coming. I don't know when it'll be included, but I had the honor of being allowed to test an "alpha version" after complaining about similar errors. Link to comment Share on other sites More sharing options...
[Me...] Posted December 13, 2018 Author Share Posted December 13, 2018 Yep that // was apart of the path...Since I've changed that path, I've had no issues loading programs or Autorun. Link to comment Share on other sites More sharing options...
[Wo...] Posted December 13, 2018 Share Posted December 13, 2018 I always prefer to map network drives and then locating paths to them. Much more stable than directly to the network path. Link to comment Share on other sites More sharing options...
