[Da...] Posted December 7, 2018 Share Posted December 7, 2018 Hello. I have done a lot of program which are very similar to each other. The pattern is the same but they are only bigger sizes(bigger casting and distances between bores). I need to write separate flatness's programs for each one. Is it any method to copy one program with polyline and expand etc ? Link to comment Share on other sites More sharing options...
[Ow...] Posted December 7, 2018 Share Posted December 7, 2018 With each program open (you can go back and forth by selecting the windows menu at top) you can copy and past features between programs. If you had cad models for each , you should be able to use the cad model comparison tool (in cad menu) BUT.... running Calypso version 6.4, I haven't had any luck using that option. I used to use it back when I programmed for production CMM's (5 years ago) and it worked well most of the time on standard features but, now, the few times I've tried, no luck at all. Link to comment Share on other sites More sharing options...
[Me...] Posted December 7, 2018 Share Posted December 7, 2018 To add to what Owen said, you can paintbrush the measurement strategy for the plane from one program to another, but you will need to recreate the polyline paths or edit the x/y/z coordinates inside of the path to change it's size. Link to comment Share on other sites More sharing options...
[Da...] Posted December 10, 2018 Author Share Posted December 10, 2018 Yeah, so that is what I thought you can use brush but still is like a new program. I have just ordered a cook book, but I think I will not get it before Christmas. Can someone take a snapshot only flatness pages ? Link to comment Share on other sites More sharing options...
[Ro...] Posted December 10, 2018 Share Posted December 10, 2018 Do you have PCM? Link to comment Share on other sites More sharing options...
[Da...] Posted December 11, 2018 Author Share Posted December 11, 2018 Unfortunately not. Link to comment Share on other sites More sharing options...
[Ro...] Posted December 11, 2018 Share Posted December 11, 2018 So parafiles are out....... Im wondering if you could use a miniplan system, but at the end of the day it would probably just be easier to do separate programs for each size. Link to comment Share on other sites More sharing options...
