[Ky...] Posted November 28, 2018 Share Posted November 28, 2018 I have a print that call Datum B Profile .01 Four spots How do I make Calypso do this I know I pick the spot face . But what else do I use?Spot Face Profile.PNG Link to comment Share on other sites More sharing options...
[Ja...] Posted November 28, 2018 Share Posted November 28, 2018 If these 4 spots are all on the same plane, I would create a plane, scan all 4 locations in the strategy, and ask for flatness. Profile of a plane with no datum reference would be the same as flatness and Calypso requires datums for profile unless you have freeform I guess. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 28, 2018 Share Posted November 28, 2018 Looks like the intent is coplanar surfaces. Collect data in all 4 places and drop the plane into a flatness characteristic with the print tolerance. You could use one plane and make sure the strategy and nominals cover the 4 places or recall feature points from 4 planes into 1. If you use the profile characteristic you have to compare the feature to itself. Same feature top to bottom with the same fit of Minimum Feature top to bottom. Your result should match the flatness result. Link to comment Share on other sites More sharing options...
[Ky...] Posted November 28, 2018 Author Share Posted November 28, 2018 I understand the flatness way you are saying . But the profile I don't quite understand. Thanks for your help bye the way Link to comment Share on other sites More sharing options...
[Me...] Posted November 29, 2018 Share Posted November 29, 2018 I see the reference of (.02) Is that stated somewhere else? Any way I see this as that they can not deviate more than +/-.005 from each other. They can as a collective float up and down +/-.01 but to each each other no more than the +/-.005. So one could be at .028 but none can go beyond .018. That's my opinion. Link to comment Share on other sites More sharing options...
[An...] Posted November 30, 2018 Share Posted November 30, 2018 Please sign in to view this quote. The intersection points create the alignment,the probing points create the profile. See attached.4_Planes_and_Profile_1.xlsx Link to comment Share on other sites More sharing options...
[Br...] Posted November 30, 2018 Share Posted November 30, 2018 Please sign in to view this quote. This is the way to do it. If you have freeform you can do a profile with no datum references. The reason for the profile callout is that its difficult to apply flatness to an interrupted surface and treat it as a single surface. for instance, If the drawing said 4X Flatness .010, it means something completely different. You would actually evaluate each surfaces flatness individually. Y14.5 added the use of profile with no datum references as a way to tie together co planar surfaces. Long story short, like Jason already mentioned it is exactly the same as flatness. All the profile does here is control form over the 4 surfaces. Link to comment Share on other sites More sharing options...
