Compound angle hole
Hello guys. Is it something special I need to do in Calypso for compound angle ?
It seems that calypso goes crazy for this.
I am using compound vise which means that actual angle hole is square, but still funny results. I need to only check two angles and do not have rotary head (DuraMax)
It sounds like you're not picking up your datums correctly. Calypso has no problem with a compound angle hole. It's all in how you set it up and what your angles are related to. Can you describe your Datums or attach a picture?
