[Pa...] Posted November 24, 2018 Share Posted November 24, 2018 angle is 120 Deg. height is 1.2mm. low diameter is 30mm the result from CMM is different from Profilometer. Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/ Share on other sites More sharing options...
[An...] Posted November 26, 2018 Share Posted November 26, 2018 Did you take a plane as a cut at the smallest diameter? Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112144 Share on other sites More sharing options...
[Br...] Posted November 26, 2018 Share Posted November 26, 2018 Please sign in to view this quote. Profilometer? Are you trying to measure Roughness on this cone? You need the ROTOS sensor to do this I believe if you want to do it through Calypso. Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112146 Share on other sites More sharing options...
[Aa...] Posted November 26, 2018 Share Posted November 26, 2018 Perhaps they meant contracer. Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112148 Share on other sites More sharing options...
[Aa...] Posted November 26, 2018 Share Posted November 26, 2018 Please sign in to view this quote. Wait, that sounds a little like you're trying to get a gauge point result. Is that what you're after? Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112150 Share on other sites More sharing options...
[Cl...] Posted November 26, 2018 Share Posted November 26, 2018 In medical device I deal with very small cones a lot. I will slice through the model in two places 90 deg apart and create four 2d curves. Scan up the ID, across the cone and over the top (lots of points/small dia probe) recall the curve points that lay on the cone surface (into 2d lines). Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112152 Share on other sites More sharing options...
[Pa...] Posted November 28, 2018 Author Share Posted November 28, 2018 Please sign in to view this quote. Sorry. I mean contracer Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112154 Share on other sites More sharing options...
[Pa...] Posted November 28, 2018 Author Share Posted November 28, 2018 Please sign in to view this quote. that is a good way,I will try. thank you! Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112156 Share on other sites More sharing options...
[Cl...] Posted November 28, 2018 Share Posted November 28, 2018 When you create the curves, use a lot of points in the initial creation. Don't triple the nominal points after its created. That way you can right click on the curve and show the exact point numbers to recall into each 2d line. Link to comment https://qualityforum.zeiss.com/topic/19872-how-to-muasure-a-short-cone/#findComment-112158 Share on other sites More sharing options...
