[ph...] Posted November 21, 2018 Share Posted November 21, 2018 dunno why it does it in old programs, but not new measurement plans done the usual: resources/results to file/check "select at cnc start" measurement tab/multiple printout/uncheck "multiple printouts active any ideas? this is killing me... Link to comment Share on other sites More sharing options...
[a5...] Posted November 22, 2018 Share Posted November 22, 2018 Check Resouces > Printout header parameters > Force Input at Start. Link to comment Share on other sites More sharing options...
[ph...] Posted November 27, 2018 Author Share Posted November 27, 2018 Thx for your time. when I do that I only get "order" as a selection in the drop down menu "serial number" is nowhere to be found any ideas? Link to comment Share on other sites More sharing options...
[Mi...] Posted November 27, 2018 Share Posted November 27, 2018 What happens when you UNCHECK the multiple PO box. Sounds like you have not set up the header variables in the PiWeb. The old report headers are still there. They will go away all together in the future but as of now you can still see them. You will need to set up Pi Web with the header variables in order to use the new stuff. Video will help some.. https://www.youtube.com/watch?v=59GBcE2FUDY Link to comment Share on other sites More sharing options...
[Ja...] Posted November 27, 2018 Share Posted November 27, 2018 Measurement tab > Multiple Printout > Select printout header parameters for input. Link to comment Share on other sites More sharing options...
[ph...] Posted November 27, 2018 Author Share Posted November 27, 2018 thx for your time its already unchecked doesn't seem to make any difference either way we've never used piweb here. I inherited the old system of custom reports that no longer seem to be working since the old guy left I plan to make the change to piweb asap meantime... Link to comment Share on other sites More sharing options...
[ph...] Posted November 27, 2018 Author Share Posted November 27, 2018 Please sign in to view this quote. Aaaaaaaahhhaa! although it doesn't seem to matter whether the boxes are checked or not... they still show up on the report header and there is no "Serial Number" selection I really appreciate your help. bit over my head at the moment. training is scheduled for January. not much help now tho Link to comment Share on other sites More sharing options...
[Ja...] Posted November 27, 2018 Share Posted November 27, 2018 I use "incremental part number" but there is "workpiece Ser. No." that you could use. If you want it to be on the custom report header, you will have to edit the header. I haven't modified mine in a long time but go to resources, design custom printout, printout head, file , open, vphead, click on what you want to add to the header from the left column and click in the header where you want it. If it was there before / in other programs, then in the "definition of multiple printout" maybe you have the wrong "output format" selected. I would compare it to the program that works right. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 27, 2018 Share Posted November 27, 2018 Please sign in to view this quote. Philip, You probably need to check your userfield.ini file to make sure it is in there. If you get training it is not part of the regular training so make sure you ask about it. Mark Link to comment Share on other sites More sharing options...
[Ri...] Posted November 27, 2018 Share Posted November 27, 2018 I believe that you still have to select the Custom Printout that has the printout header information to get everything to work correctly. Link to comment Share on other sites More sharing options...
[Te...] Posted November 27, 2018 Share Posted November 27, 2018 Have a look at this it should help. Wrote this for customers because it is not covered in a training class very often. It is dated and soon to become mostly obsolete with custom printout leaving but should get you enough info to get your serial number or anything else back in the custom printout header.Customizing Output Calypso June 2015.pdf Link to comment Share on other sites More sharing options...
