[Da...] Posted November 5, 2018 Share Posted November 5, 2018 Hi, I would just like your opinion, how would you set up datums A and B? "A" would consist of A1, A2 and A3. I have symmetry 2 for primary datum, (took cylinders A2 and A3 into symmetry 1, took symmetry 1 and cylinder A1 into symmetry 2) For secondary, I was thinking like 3D line between symmetry 1 and cylinder A1. Is there more sophisticated way to set up datums A and B? please check the attachments I'm using Calypso 6.4.20cyl.zipcyl.sat.zipcyl.pdf Link to comment Share on other sites More sharing options...
[Da...] Posted November 20, 2018 Author Share Posted November 20, 2018 I'm guessing, for spatial (A), recalling points from cylinders A1, A2, and A3 into a new cylinder might be a bad idea? Link to comment Share on other sites More sharing options...
[Ja...] Posted November 20, 2018 Share Posted November 20, 2018 Datum A is a hole pattern. I would measure 3 cylinders A1, A2, and A3, and set the evaluation of each to outer tangent. Create an intersection of each cylinder to the top plane and bottom plane. Create a point recalling the top 3 and a point recalling the bottom 3. Create a 3D line from those two points and call it your datum A. Datum B either don't make sense or it has me stumped. Long story short, I would use the plane at the bottom of the 31.5 distance by itself. The symmetry between that plane and a single point is not going to change anything. The symmetry or the plane by itself will be the same. Or, is that a distance between the cylinders. It's not clear. Link to comment Share on other sites More sharing options...
[Ja...] Posted November 20, 2018 Share Posted November 20, 2018 The more I think about it I think that symmetry would be different than the plane by itself. I'm not sure how to go about constructing that datum B. Link to comment Share on other sites More sharing options...
