Scanning a Radius surface
I have had good luck using a combination of circle paths at different angles around the axis and a series of circles along the axis.
Depending on the size of the hemisphere, point masking at the beginning of the scans may be an issue, in that case, making paths in both directions along the axis can assure that you points along the entire scan.
