Probe Calibration Program
I still have not found a solution. Even with a Custom Report, having the result element characteristic for probe deviation will not show up on any report I use.
Is your syntax in the formula correct? Should read as getProbe("Stylus Name","Stylus System").stdProbeDev
an example of one of mine is getProbe("3_+X","Q-10 Tee").stdProbeDev/25.4
The /25.4 changes the results to inches
The image below is the settings I have in our program and it works fine in Custom Printout at least, I have not converted the calibration programs we use over to piWeb yet.
I was thinking it could possibly be if you were using it as a 'number' instead of a 'length'?
Just a thought, other than that I do have my calibration programs setup so they are grouped by probe with the probing system qualification just prior to the result element for standard deviation, I doubt this makes any difference but figured I would specify what I have that is working.
