[Me...] Posted November 12, 2018 Share Posted November 12, 2018 When using Result Element for the .stdProbedev, results will not show up on a Pi-Web printout? Link to comment Share on other sites More sharing options...
[Me...] Posted November 13, 2018 Author Share Posted November 13, 2018 I still have not found a solution. Even with a Custom Report, having the result element characteristic for probe deviation will not show up on any report I use. Link to comment Share on other sites More sharing options...
[Mi...] Posted November 13, 2018 Share Posted November 13, 2018 Is your syntax in the formula correct? Should read as getProbe("Stylus Name","Stylus System").stdProbeDev an example of one of mine is getProbe("3_+X","Q-10 Tee").stdProbeDev/25.4 The /25.4 changes the results to inches Link to comment Share on other sites More sharing options...
[Me...] Posted November 13, 2018 Author Share Posted November 13, 2018 Yes the formula is correct. I can see my results in the Characteristic just not able to have it on any type of report. Link to comment Share on other sites More sharing options...
[De...] Posted November 13, 2018 Share Posted November 13, 2018 The image below is the settings I have in our program and it works fine in Custom Printout at least, I have not converted the calibration programs we use over to piWeb yet. I was thinking it could possibly be if you were using it as a 'number' instead of a 'length'? Just a thought, other than that I do have my calibration programs setup so they are grouped by probe with the probing system qualification just prior to the result element for standard deviation, I doubt this makes any difference but figured I would specify what I have that is working. Link to comment Share on other sites More sharing options...
[Ri...] Posted November 13, 2018 Share Posted November 13, 2018 What version of Calypso are you running. I just tested it on my offline seat in 2017, and it works fine. Link to comment Share on other sites More sharing options...
