[Cl...] Posted November 8, 2018 Share Posted November 8, 2018 I curious what the general opinion is about using helix paths in cylinders? I have a customer program that uses this strategy for several cylinders. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/ Share on other sites More sharing options...
[Mi...] Posted November 8, 2018 Share Posted November 8, 2018 I will use the helix path if the is any form tolerance (cylindricity etc.) just for full coverage of the feature. If I don't have a proper stylus to do it then circles with line paths along the axis Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112686 Share on other sites More sharing options...
[Cl...] Posted November 8, 2018 Author Share Posted November 8, 2018 What about as a Datum? Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112688 Share on other sites More sharing options...
[Mi...] Posted November 8, 2018 Share Posted November 8, 2018 Yes even if the feature is used as a datum, with the appropriate Evaluation. Although there may be some additional arguments because it shows any form issues that may be going on over the length of the part and not just where the circles are located Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112690 Share on other sites More sharing options...
[Ri...] Posted November 8, 2018 Share Posted November 8, 2018 Helix paths are fast and can be slightly more imprecise then lines on a cylinder. Full disclosure, that opinion is based only on a couple days study on a limited number of sizes, materials, and surface finishes. Testing on your parts and finishes would be the best course. What are the constraints here? Is run time the issue or precision? What are the manufacturing methods? Jig bore or stamping or regular machining practices? One of the big problems with measuring cylinders is the short, large diameter cylinder. Is that an issue here? Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112692 Share on other sites More sharing options...
[Cl...] Posted November 8, 2018 Author Share Posted November 8, 2018 Thanks Richard. I went through their program and found datum features using helix strategies. I replaced the helix path with circle paths, and improved the position results by 2x. I rarely use this strategy, so I was curious what the difference would be if I made the change? Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112694 Share on other sites More sharing options...
[Ri...] Posted November 8, 2018 Share Posted November 8, 2018 In my 27 years experience with CMM's part programming, both in UMESS and Calypso, two circle paths will get the job done. That's for generous tolerances and solid, repeatable manufacturing methods. For close tolerance bores or for bores made from less dependable methods, I liked a combination of circle and line paths. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112696 Share on other sites More sharing options...
[Aa...] Posted November 9, 2018 Share Posted November 9, 2018 If you're evaluating the cylinder using a tangential evaluation technique, I would strongly advise against using only a few helical paths. The position/orientation results can be unstable. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112698 Share on other sites More sharing options...
[Da...] Posted November 9, 2018 Share Posted November 9, 2018 I check cylinders all day, every day. I never use helix. The most stable way to check cylinders for our parts is to use several circles the recall feature points into a cylinder only for Cylindricity. This way we have roundness of individual circles available for analysis if needed. Viewing the circles individually make it easy to spot contamination. Honing can produce a perfectly round hole that is bent like a banana. Can you extract circles from a helical scan? can you analyse roundness? I build features that answer question that I know will arise from a not so good part. Saves lots of time in the end. Just my 2 cents. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112700 Share on other sites More sharing options...
[Ca...] Posted November 9, 2018 Share Posted November 9, 2018 I only use helix scans for threads. For holes, I use circle scans for size, and recall lines through circles for location. Some of our customers have requested these methods. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112702 Share on other sites More sharing options...
[He...] Posted November 9, 2018 Share Posted November 9, 2018 I have found it will give very repeatable results, but not accurate results for true positioning. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112704 Share on other sites More sharing options...
[Cl...] Posted November 9, 2018 Author Share Posted November 9, 2018 Yes, that's what I'm seeing too. thanks to everyone for the input. Link to comment https://qualityforum.zeiss.com/topic/19966-helix-path/#findComment-112706 Share on other sites More sharing options...
