Live Measuring Result Missing
Hi,
I think I must have changed a global setting somehow. When running a program in Gear Pro, the ‘live’ result no longer appears on screen during measuring. This is happening on current programs and any new ones a create. I can still view the results once measuring has completed by means of a hard copy. Is there a universal setting to turn the on-screen results on/off during measurement?
Thanks
I don’t know if GearPro uses Default Printout for this function but you can try going to Resources- Define Printout. Select the Default Printout tab and uncheck the Background option. This will produce live results duriya Calypso run.
  • 4 months later...
Is this problem still existing?
Have you already contacted the supports team?
In GEAR PRO there exists no global setting for deactivating the preview.
Only in the created programs (.gear) you can deactivate the preview of results during the measurement.
See screenshot.
3.jpgFetching info...
