[Me...] Posted November 5, 2018 Share Posted November 5, 2018 Hello, Is there a way that I can turn off x y or z from showing up on the custom printout with additional printout selected. Thanks. Link to comment https://qualityforum.zeiss.com/topic/20000-additional-printout-xyz/ Share on other sites More sharing options...
[Ro...] Posted November 5, 2018 Share Posted November 5, 2018 I thought the reason the XY&Z numbers were showing up was because of Additional Printout. Turn it off?? Link to comment https://qualityforum.zeiss.com/topic/20000-additional-printout-xyz/#findComment-112910 Share on other sites More sharing options...
[Me...] Posted November 5, 2018 Author Share Posted November 5, 2018 I would like to turn off just X or just Y and have the others still show. Sometimes these values are useless for the operator to adjust their machine. Link to comment https://qualityforum.zeiss.com/topic/20000-additional-printout-xyz/#findComment-112912 Share on other sites More sharing options...
[Ro...] Posted November 5, 2018 Share Posted November 5, 2018 Do you have PCM 🙂 You can add x y & Z or anything else you want or need to the comment section. I add MIn & Max to all my profiles because Min & Max are big where i'm at, and i don't want my reports to all be 6 pages long. without PCM you Might be able to do it with a result element, turn the additional results off and just put a result element in line behind your TP so it shows up in place.min max1.JPG Link to comment https://qualityforum.zeiss.com/topic/20000-additional-printout-xyz/#findComment-112914 Share on other sites More sharing options...
