Additional Printout XYZ
I would like to turn off just X or just Y and have the others still show. Sometimes these values are useless for the operator to adjust their machine.
Do you have PCM 🙂
You can add x y & Z or anything else you want or need to the comment section.
I add MIn & Max to all my profiles because Min & Max are big where i'm at, and i don't want my reports to all be 6 pages long.
without PCM you Might be able to do it with a result element, turn the additional results off and just put a result element in line behind your TP so it shows up in place.
