Pi Web and AutoRun no bueno
Good afternoon. Running 6.6 Calypso. When running in autorun, I always have "force input parameters" checked on the results to file section, so that the user can input machine, nest, and pallet. So when you run a part THAT HAS a previous custom printout, it will do exactly as I need it to do. Which is at the beginning of run, it stops to allow you to input. For all 3 pallets (I have 3 pallets).
But when you run a new program WITH ONLY PiWeb (No old custom printouts), it does not work. Meaning it just continues run, without allowing you to input any parameters.
Any suggestions?
Sorry. I wasn't telling him to use the Custom Printout. I was having him select his Custom Printout, so his custom variables would show up in the prompt.
Thanks everyone! I figure it out. Being new to this company (6months), there are multiple programs in separate folders (thats a whole other story). So it seems there are "same name" programs. So I assumed I was changing/working on the correct program, and was not. So all the changes were not taking affect. Hence the problem. It works perfectly now.
THANKS!
