[Lu...] Posted October 31, 2018 Share Posted October 31, 2018 Good afternoon. Running 6.6 Calypso. When running in autorun, I always have "force input parameters" checked on the results to file section, so that the user can input machine, nest, and pallet. So when you run a part THAT HAS a previous custom printout, it will do exactly as I need it to do. Which is at the beginning of run, it stops to allow you to input. For all 3 pallets (I have 3 pallets). But when you run a new program WITH ONLY PiWeb (No old custom printouts), it does not work. Meaning it just continues run, without allowing you to input any parameters. Any suggestions? Link to comment Share on other sites More sharing options...
[To...] Posted November 1, 2018 Share Posted November 1, 2018 The ability to "force input at start" is located under Resources - Printout Header Parameters. Maybe this is what you meant to say. Link to comment Share on other sites More sharing options...
[Lu...] Posted November 1, 2018 Author Share Posted November 1, 2018 It is checked. And it will not work. that is the question. It should but doesn't. Link to comment Share on other sites More sharing options...
[To...] Posted November 1, 2018 Share Posted November 1, 2018 Luis, I just tested it with an old program and with a new program and it worked both times. Not sure what is happening on your machine. Link to comment Share on other sites More sharing options...
[Ri...] Posted November 1, 2018 Share Posted November 1, 2018 Go into Resources - Define Printout - Custom Printout, and select your Custom Printout. See if that works. Link to comment Share on other sites More sharing options...
[To...] Posted November 1, 2018 Share Posted November 1, 2018 Please sign in to view this quote. You will have to disable Multiple Printout first. Or, select the Presentation printout within Multiple Printout. Link to comment Share on other sites More sharing options...
[Ri...] Posted November 1, 2018 Share Posted November 1, 2018 Please sign in to view this quote. Sorry. I wasn't telling him to use the Custom Printout. I was having him select his Custom Printout, so his custom variables would show up in the prompt. Link to comment Share on other sites More sharing options...
[Lu...] Posted November 2, 2018 Author Share Posted November 2, 2018 Thanks everyone! I figure it out. Being new to this company (6months), there are multiple programs in separate folders (thats a whole other story). So it seems there are "same name" programs. So I assumed I was changing/working on the correct program, and was not. So all the changes were not taking affect. Hence the problem. It works perfectly now. THANKS! Link to comment Share on other sites More sharing options...
