[Ja...] Posted October 30, 2018 Share Posted October 30, 2018 Hi, forum! Does anyone know what this error message means? Occasionally when the stylus makes contact with a surface, it stalls and takes several seconds to register a hit. When you view the vectors, this initial hit is often absent. I'm curious as to whether it's affecting our accuracy or not. If anyone can contribute, it would be most appreciated! Our CMM is a model MMZ-B (running Calypso 2016), equipped with an RDS articulating head and a Vast XXT sensor. Link to comment Share on other sites More sharing options...
[Me...] Posted October 31, 2018 Share Posted October 31, 2018 I had this problem about 4 years ago with a ST3 head. So I'm not sure they relate but it ended up being the head going bad. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 31, 2018 Share Posted October 31, 2018 This is a indication the controller can't make sense of the data provided by the XXT. It could be the head is damaged or it could also be a dirty adaptor plate. Your best bet is to call into Zeiss and having Service take a look at it. Link to comment Share on other sites More sharing options...
[Lo...] Posted November 1, 2018 Share Posted November 1, 2018 We have seen some strange behavior with the vectors when a person doesn't retract off the work pc perpendicular to the work surface. E.g. the last point on a circle feature was taken and instead of retracting the probe off the circle feature, the person just raised the stylus not retracting 1st. This throws Calypso for a loop and the vectors were all screwed up. Link to comment Share on other sites More sharing options...
