[Me...] Posted November 1, 2018 Share Posted November 1, 2018 Hello. Has anyone else ever run into this... The True Position result in my printout is showing different actuals for Y,Z than the actuals in the Features window for the referenced feature. As a result, the T.P. result is different (and incorrect) than when I calculate it manually. The T.P. result is roughly half of what it should be. If I delete the actuals and rerun the cnc plan, the same problem exists. What are the possible causes for this? Thanks. Link to comment https://qualityforum.zeiss.com/topic/20040-true-position-actuals-variation/ Share on other sites More sharing options...
[Cl...] Posted November 1, 2018 Share Posted November 1, 2018 Is the value displayed in the feature window relative to a different alignment than the characteristic? Link to comment https://qualityforum.zeiss.com/topic/20040-true-position-actuals-variation/#findComment-113240 Share on other sites More sharing options...
[Br...] Posted November 1, 2018 Share Posted November 1, 2018 Are you using the same evaluations on the feature as well as the same coordinate system in your position characteristic? If your feature refers to the base alignment, and the Position Characteristic refers to something else, you will get different results. Even if you are using the same Datum Features in the Position Characteristic, but they have different evaluations then they do in the base alignment, (especially if you have the Form Datum option turned on) you can get very different results. Link to comment https://qualityforum.zeiss.com/topic/20040-true-position-actuals-variation/#findComment-113242 Share on other sites More sharing options...
