[Me...] Posted October 30, 2018 Share Posted October 30, 2018 I am trying to program a flat part using the optics on our O-Inspect 322. I am having trouble with a few measurements and am asking for advice on strategy. I don't know how I would program these measurements.These measurements are highlighted in the attached drawing. Thanks for your help.Drawing.PNG Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/ Share on other sites More sharing options...
[Da...] Posted October 30, 2018 Share Posted October 30, 2018 I'm not familiar with the software features for the o-inspect machines, but part of the answer would be to have the engineer who drafted the drawing clarify which feature or features datum callouts A and B are tied to. Once you know that, it is easier to come up with a strategy on how to structure your measurement plan. Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/#findComment-113266 Share on other sites More sharing options...
[Cl...] Posted October 31, 2018 Share Posted October 31, 2018 Do you have specific questions about camera settings? Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/#findComment-113268 Share on other sites More sharing options...
[Me...] Posted October 31, 2018 Author Share Posted October 31, 2018 How would I create the lines (from the center of that main circle) to get the angles I want measured? Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/#findComment-113270 Share on other sites More sharing options...
[Cl...] Posted October 31, 2018 Share Posted October 31, 2018 Measure each radii. Recall each radii with the main circle into a 3d line. I would also project all the features to the same plane before the construction. Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/#findComment-113272 Share on other sites More sharing options...
[An...] Posted October 31, 2018 Share Posted October 31, 2018 Measure Ø 31,62mm and use as base system! Measure Ø 1,59mm and use as secondary alignment! Now you make a rotation division, in this way you only have to measure the Ø 1,59mm once! Now you create a new circle and make a recall of all Ø 1,59mm and you get as a result the R 17,45mm. In two circles ( Ø 1,59mm ) you put a 2d-straight line and choose "Angle between elements" and you get the angle 45°. You halve this angle and have as result the angle 22,5°. Link to comment https://qualityforum.zeiss.com/topic/20046-optics-help/#findComment-113274 Share on other sites More sharing options...
