[Ri...] Posted October 25, 2018 Share Posted October 25, 2018 Calypso v6.2.x Vast XT Gold I seem to have ran into an issue where I have a plane in the XZ, XY axii. Using a stylus in the Z- position I probe around the plane 180 degrees. In order to avoid colliding with the part I need an arc motion to move around the Ø4.025 "Circle Path" for the plane. I used the "Fixed Path" which provides for arc motion. Now, all my planes are in touch trigger mode whether I select points or scanning. Attached is a sample program, I have removed the model but left an image "model.jpg" for viewing. Plane1, Circle1 and Circle2 use a Ø3mm x 90mm stylus in the Z- axis Plane2 uses a Ø3mm x 90mm in Y+ and Y- axis. Any assistance would be appreciated. All my programs now move in trigger points regardless of settings. Oh yea, and when this happens, the flatness of my model surface is way out of tolerance 🤣8040xxx_B_20_10-25-xx.zip Link to comment Share on other sites More sharing options...
[To...] Posted October 25, 2018 Share Posted October 25, 2018 What is "Fixed Path"? I've never heard of this option. Link to comment Share on other sites More sharing options...
[Cl...] Posted October 25, 2018 Share Posted October 25, 2018 So you want it to scan? Link to comment Share on other sites More sharing options...
[Cl...] Posted October 25, 2018 Share Posted October 25, 2018 I open your program and tried to un-tick single points, and saw this error message. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 I "used" fixed path on plane1, I removed fixed path on plane2. Plane2 is still using points. It seems every plane after will not scan. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 Please sign in to view this quote. I did not get any error messages. Link to comment Share on other sites More sharing options...
[To...] Posted October 25, 2018 Share Posted October 25, 2018 Can you explain what the purpose of fixed path is. Never used it in 15+ years. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 25, 2018 Share Posted October 25, 2018 When I opened the program it shows scanning paths. The Single Points box was not checked. Mark Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 Please sign in to view this quote. I do not recall who posted this PDF file, but I believe it was how to make a plane probe in arc motion. I had forgotten I had the file, today I was trying to make the plane move around a circumference and stumbled upon it. I changed my setting and it worked, then all planes started working only in trigger type mode while circles scanned as planned. This seems to be restricted to the CMM program provided, my other programs appear unaffected.CirclePathOnPlane.pdf Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 Please sign in to view this quote. Is this showing as "checked" for some and "unchecked" for others? Link to comment Share on other sites More sharing options...
[Ma...] Posted October 25, 2018 Share Posted October 25, 2018 Measurement Strategy Plane1 and Circle1 - Checked (4 Points) Plane2 (both Circle Paths ) and Circle2 - Unchecked Fixed Path Plane1 - Checked Plane2 - Unchecked Mark Link to comment Share on other sites More sharing options...
[Ma...] Posted October 25, 2018 Share Posted October 25, 2018 Please sign in to view this quote. Tom here is the help file explanation Mark Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Share Posted October 25, 2018 Yes, the Fixed Path is ONLY for single points measurement. If you are scanning a circle path, it's already going to be on a "fixed path." Is it possible for you to just either add more to your retract distance to avoid the other point? I always tell people that I avoid having to put position points at all cost. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 Please sign in to view this quote. I understand what "Fixed Path" is for, problem that arose is, after enabling it on a single Plane feature, all planes were now trigger type, they will not scan. Add to that, the form of the plane will be exaggerated greatly. In the CMM program provided, when I unchecked "Fixed Path" in Plane1, Plane2 had "Form" of .027". Which from the model, I'm leaning towards it not having bad form. 🤠 Link to comment Share on other sites More sharing options...
[Br...] Posted October 25, 2018 Share Posted October 25, 2018 So does it still take single points when the single point checkbox is unchecked? Link to comment Share on other sites More sharing options...
[To...] Posted October 25, 2018 Share Posted October 25, 2018 Please sign in to view this quote. Thanks Mark, I saw the help description but didn't quite understand what it was trying to say. I've always circumvented it with position points. The fixed 2.png pic was worth 1000 words. LEARN SOMETHING NEW EVERY DAY. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 25, 2018 Author Share Posted October 25, 2018 Please sign in to view this quote. The planes took single points regardless of checked or unchecked after initial setting of checked for Fixed Path. Link to comment Share on other sites More sharing options...
[Br...] Posted October 25, 2018 Share Posted October 25, 2018 Please sign in to view this quote. Weird. This is usually the point where I completely terminate my session with Calypso and restart. Link to comment Share on other sites More sharing options...
[Gr...] Posted October 30, 2018 Share Posted October 30, 2018 Here is my best explanation of fixed path. On occasion we have a plane with islands or protrusions on them. When measuring these planes we will sometimes use circle on a plane and because of material make up we will check single points and under Number of points call out 10. If the measurement is run at this point the CMM will make straight linear moves from point to point. If there is a island or protrusion or feature in those straight lines a collision can occur. To avoid this under Special Settings check fixed path. Now when measured, the stylus will follow the diameter you defined when setting up circle path. Hope this helps. As a heads up we are running Calypso 6.4.2003 and have not encountered a problem with this Link to comment Share on other sites More sharing options...
