[Hu...] Posted October 25, 2018 Share Posted October 25, 2018 Hello, I would like the best way to program a move that would allow the probe to go up and over 3 different jaws on a chuck. The probe will smack the jaw when checking a run out for the gear teeth instead of skipping up and over it. Thanks Jim Link to comment Share on other sites More sharing options...
[Hu...] Posted October 25, 2018 Author Share Posted October 25, 2018 I forgot tot mention this is for the Zeiss Vast XT Link to comment Share on other sites More sharing options...
[To...] Posted October 25, 2018 Share Posted October 25, 2018 If your strategy is single points, you can insert a clearance data (icon that looks like an ice cube) in between each point. You can also copy and paste the clearance data at the beginning of the strategy list. So, it will look like this: Clearance Data Probing Point Clearance Data Probing Point Clearance Data Probing Point This assumes you're using CP+Z and your clearance plane is above the jaws. Link to comment Share on other sites More sharing options...
[Cl...] Posted October 25, 2018 Share Posted October 25, 2018 Sounds pretty straight forward? You could use a position point after each probing. Or you could insert Clearance Data between points, both under strategy. Link to comment Share on other sites More sharing options...
[Cl...] Posted October 25, 2018 Share Posted October 25, 2018 Tom beat me to it. 😃 Link to comment Share on other sites More sharing options...
[Hu...] Posted October 25, 2018 Author Share Posted October 25, 2018 Thank You, I will give a try Link to comment Share on other sites More sharing options...
