Programming move / Jaws on chuck
Hello, I would like the best way to program a move that would allow the probe to go up and over 3 different jaws on a chuck. The probe will smack the jaw when checking a run out for the gear teeth instead of skipping up and over it.
Thanks
Jim
If your strategy is single points, you can insert a clearance data (icon that looks like an ice cube) in between each point. You can also copy and paste the clearance data at the beginning of the strategy list. So, it will look like this:
Clearance Data
Probing Point
Clearance Data
Probing Point
Clearance Data
Probing Point
This assumes you're using CP+Z and your clearance plane is above the jaws.
Sounds pretty straight forward? You could use a position point after each probing.
Or you could insert Clearance Data between points, both under strategy.
