Planner
Contura 2014 - Vast XXT-RDS CAA
I've figured out how to fix this issue before with an XTR but for some reason nothing is working with the RDS...I've deleted my machine several times to start over, calibrated the MasterProbe also and still nothing doing with Calypso 2018 Ver. 6.6.
Normally, I find you don't need to do Ref Sphere Positions or Qualify Stylus for normal probes but when it comes to RDS-CAA, I have found going through all of the normal calibration and fitting position routines were necessary.
I've tried multiple different numbers Tom...First I used my actual machine's numbers and then I found from another post instructions to find the numbers in the User Guide, I believe they were 0.000, 55.000, 135.000. Still nothing works.
I believe those number were for a Renishaw RDS Adapter Plate.
Going back a week or two ago, I had a similar issue but it was resolved after I created a new machine tab. I think the new SP is due in early November. Might be worth the wait.
