Stylus System Creator
Is there a way after you have crated the probe(s) that you can import the angles that you already have or do I need to now create all of the angles as well?
First, open the RC List window with the Stylus System with all of the probe angles you already have. Save the list. Then, Import the SSC file into Calypso and then through the RC List window, you can read in the text file of your positions. This can be a finicky operation which MAY create a duplicate 1 probe but I have seen it work.
