"Select printout header parameters" settings
Have you tried copying the files userfields.ini and systemfieldsassistance.ini (if present) from the protform folder? If that doesn't do it, the info may be stored in the inspection file.
The "userfields.ini" doesn't contain all the information, only a couple items.
The "systemfieldsassistance.ini" doesn't seem to exist at all.
