[Ja...] Posted October 15, 2018 Share Posted October 15, 2018 Is there a way to add pictures to the measurement plan to pop up before the plan start to assure the part is in the correct place? Link to comment Share on other sites More sharing options...
[Cl...] Posted October 15, 2018 Share Posted October 15, 2018 I only know how to do this in autorun. Are you using autorun? Link to comment Share on other sites More sharing options...
[Ja...] Posted October 15, 2018 Author Share Posted October 15, 2018 I'm not sure. I click run every time. Link to comment Share on other sites More sharing options...
[He...] Posted October 15, 2018 Share Posted October 15, 2018 Yes, after you hit "Run", find the tab "User Information". It will give you the file path to upload pictures, setup sheets, etc. Once you upload your file, when you click "user Information", your pictures will open up for the operator. Link to comment Share on other sites More sharing options...
[Me...] Posted October 16, 2018 Share Posted October 16, 2018 I link setup sheet .pdf's in the user information area like Mark mentioned. Here are some screenshots.user-definable measurement run info for CNC start run window.png Link to comment Share on other sites More sharing options...
[Mi...] Posted October 16, 2018 Share Posted October 16, 2018 You can use a batch file in your plan folder. If the batch file name is... "inspection_post_load.bat" the picture will show up when you open the plan "inspection_pre_start_dialog.bat" the picture will show up when you press the CNC-Start button "inspection_start.bat" the picture will show up when you start measuring Example to show a picture with the CZViewer: @ECHO OFF "C:\Program Files (x86)\Zeiss\Calypso\opt\om\bin\winnt\czviewer.exe" X:\Userinfo\MY_PICTURE.jpg ("Path_to_CZViewer" Path_to_picture.jpg) to show a picture with the Windows Viewer: @ECHO OFF X:\Userinfo\MY_PICTURE.jpg You can also show pdf, video or whatever you like more info at Calypso-help (F1 button) search for "batch" Link to comment Share on other sites More sharing options...
[Me...] Posted October 16, 2018 Share Posted October 16, 2018 Is there a way to turn of the User Information instructions after you've turned it on? Link to comment Share on other sites More sharing options...
[Mi...] Posted October 17, 2018 Share Posted October 17, 2018 Yes,there is one, but not in Calypso Close your plan. Open the plan folder. Edit the file "inspset" with (windows)editor and delete the part #( #graphicUserInfo ' ->' 'path_to_picture.jpg') if you use autorun, do the same at file "autoruninf" Link to comment Share on other sites More sharing options...
[Er...] Posted October 17, 2018 Share Posted October 17, 2018 You could also do this if you have pcm and like to edit while program is open. settingPut("graphicUserInfo","") It's also possible to define. settingPut("graphicUserInfo","c:\nakedstuff\samanthafox.jpg") Link to comment Share on other sites More sharing options...
