[Ju...] Posted September 21, 2018 Share Posted September 21, 2018 Good morning all, Has anyone find a way to change the settings from reading Radians to Degrees, Mins, Secs in PiWeb? I am using the basic one that comes with the software and we have Calypso 6.4.04. My company does not want to buy the plus or above just yet. Any help is appreciated.. Link to comment https://qualityforum.zeiss.com/topic/20144-angles-reporting-in-piweb/ Share on other sites More sharing options...
[e1...] Posted September 24, 2018 Share Posted September 24, 2018 I'm not sure if you're on an SMA or not, but if you are eligible to be licensed for Calypso 6.6, this has been addressed in the Tools > Settings part of the PiWeb editor. It allows you to select Deg/Min/Sec as the output angle format. Unfortunately I don't know off the top of my head how to answer your question for Calypso 6.4. Link to comment https://qualityforum.zeiss.com/topic/20144-angles-reporting-in-piweb/#findComment-113840 Share on other sites More sharing options...
[An...] Posted October 5, 2018 Share Posted October 5, 2018 In Calypso 6.4 there is only one radiant angle! Only from version 6.6 is a representation in degrees, minutes, seconds possible! Link to comment https://qualityforum.zeiss.com/topic/20144-angles-reporting-in-piweb/#findComment-113842 Share on other sites More sharing options...
[Ju...] Posted October 15, 2018 Author Share Posted October 15, 2018 Thank you Laura and Andreas for your response. I will need to see about getting the 6.6 version. Link to comment https://qualityforum.zeiss.com/topic/20144-angles-reporting-in-piweb/#findComment-113844 Share on other sites More sharing options...
