[Da...] Posted October 15, 2018 Share Posted October 15, 2018 Hello Guys. I am trying to write a proper program using threads measurements without PCM. These threads are not in the same positions every time. I would love to have something like: Message to operator "Check the form [form value showing up] if is more than 0.08 increase start angle by 90[start angle input parameter" or program can checks this itself and repeat measurement without operator interference. Is this possible at all ? I have a bad results but I know that this is affecting by form and I cannot calculate start position from face as they are on random positions so I ma looking for the best method. Link to comment Share on other sites More sharing options...
[Ro...] Posted October 15, 2018 Share Posted October 15, 2018 I dont know if i completely understand your question, from what i gather you are dealing with a bolt circle that isnt constrained, and from part to part may vary. You may be able to have the operator take a manual point with the joystick button, say "put the probe tip in the center of the hole and hit the button on the top of the joystick", then using a simple formula set your nominals to the X&Y of the manual point? For the life of me i cant remember how to setup a manual point, i know its easy i just haven't done it in about 5 or 6 years. Am i even close? Link to comment Share on other sites More sharing options...
[Da...] Posted October 15, 2018 Author Share Posted October 15, 2018 No. You misunderstood me. I am checking thread holes. Because they have been done manually the thread start position is not always in the same place so the form is no good. Link to comment Share on other sites More sharing options...
[Tr...] Posted October 15, 2018 Share Posted October 15, 2018 Ryan Stauffer had a lunch and learn about the best way to measure threads. Ill attach the pdf to see if it helps. Link to comment Share on other sites More sharing options...
