Default Routine Settings
Good Afternoon everyone,
I was wondering if there is a way in calypso to set up some default settings for protforms so every time you click "Create New Measurement Plan" it would select the same custom protform for the PDF print out. currently I have a saved "Blank" program that has all my settings, Defaults, and protforms set up and ill just open and save this "blank" program with the item number of the part im getting ready to write for. This has worked for me for several years just wondering if this is possible with calypso.
Just to make sure: We're not talking about PiWeb reporting here, right?
To have your default settings ready in any new plan, put all your custom report / header / etc. files in the \protform\default folder (rename the original if necessary). There's no other way than this (except what you already do).
Make sure to back up the \default folder, as it will be overwritten by every upgrade or service pack you install.
