[To...] Posted September 21, 2018 Share Posted September 21, 2018 I've got an air foil part. There are 5 datum targets A1, A2 and A3 for Spatial and Z, B1 and B2 for Planar and X. For the tertiary (Y), they're specifying a cylinder as Datum C. Do you think it would be okay to measure C as a circle, create a point, recall Circle_C and use in my RPS alignment along with my 5 other points? I just noticed that I can select the circle in my RPS alignment, so I guess I don't need to create the 6th point. Link to comment Share on other sites More sharing options...
[An...] Posted September 25, 2018 Share Posted September 25, 2018 _ Link to comment Share on other sites More sharing options...
[To...] Posted October 6, 2018 Author Share Posted October 6, 2018 Here's a little more to this project. I'm set on using the 5 datum targets for A and B to control Z and X in an RPS alignment. I was planning to use a circle on cylinder C as the 6th target point to control Y, but now I'm questioning if I shouldn't be using a cylinder instead of a circle. I know I can't use a cylinder for the RPS alignment but I was thinking I could use an intersection of the cylinder axis but to what? Can I use a theoretical X plane, located by the B points for my intersection? B1 and B2 both have the same X value relative to axis A. Also, I'm looking at the True Position of C to A and B. Since A and B are not features that I can use in my TP, I'm planning to create a Geometry Best Fit Alignment using datum targets A1, A2, A3, B1 and B2 ( only allowing translation in the Y). Then, and do a best fit bore pattern of cylinder C to this GBFA. Or, should I just refer to the Base Alingment from above? Am I overthinking this? For other features, that use A, B and C, my plan was to use the best fit bore pattern alignment. Sound ok? I've attached a cleaned up drawing so you can sort of visualize my application. How would you guys approach the alignment and the TP of C?RPS Example 1.pdf Link to comment Share on other sites More sharing options...
[An...] Posted October 8, 2018 Share Posted October 8, 2018 _ Link to comment Share on other sites More sharing options...
[Br...] Posted October 8, 2018 Share Posted October 8, 2018 You could use the RPS alignment like you explained for your X and Z, then either use the circle of Datum feature C or just any point in the Y direction just to lock it down. Then create a regular alignment but have it reference the RPS alignment you've already made, and drop your Datum C cylinder in the Y origin box. Leave everything else blank and the alignment will refer back to the RPS alignment you made to constrain the other degrees of freedom. Link to comment Share on other sites More sharing options...
[To...] Posted October 8, 2018 Author Share Posted October 8, 2018 Please sign in to view this quote. I understand what you said but I have a question. Let's say I create a standard alignment on a cubed part using 2 planes for Z and X origin and a cylinder for the Y origin, the Y zero would be calculated from the intersection of the C cylinder and X origin plane. In my application, the location of the X origin is calculated from B1 and B2 but those points are not X zero on the model. Does this mean the Y origin will be calculated from the intersection of the axis of C at models' X origin. Link to comment Share on other sites More sharing options...
[Br...] Posted October 8, 2018 Share Posted October 8, 2018 That's a really good question. You could try to measure a circle inside the cylinder and see if there is a significant difference in location in the Y direction. You could also try to constrain the Cylinder in the Z direction in the alignment. Or you could create a theoretical YZ plane within the RPS alignment. this should be nominaly perpendicular to the cylinder if I understand correctly. With the form datum setting on, use an outer-tangential evaluation on the cylinder, and constrain it to that theoretical plane. Let me know if that doesn't make sense. Link to comment Share on other sites More sharing options...
