MasterProbe is invalid
Brian, based on the screenshot that Daniel posted, it doesn't appear this machine is capable of CAA so Fitting Position is not necessary. CAA is only available on TL-3 sensors.
Anyway, the Ref Sphere Position must be done before the Fitting Position.
Daniel, did you create a new machine tab, or did you create a backup of your config folder and use it to get your machine tab?
Finally I did manage to solve the problem. It took me fu*kin 3 hours. I did create a new machine tab and then pasted config folder.
The solution was that I had to press "Yes" for "Update stylus". I pressed No and did not know that this can affect something later on. Anyway thanks for help.
