[Da...] Posted October 4, 2018 Share Posted October 4, 2018 Hello. I had to reinstall the Calypso. That's what I have got after putting Sphere details. Any ideas what to do ? This is after clicking on the ref.sphere position. Link to comment Share on other sites More sharing options...
[Ja...] Posted October 4, 2018 Share Posted October 4, 2018 I would wait for more comments but I think you may need to redefine the master probe length first. Link to comment Share on other sites More sharing options...
[Br...] Posted October 5, 2018 Share Posted October 5, 2018 I believe you will need to run the "fitting position" for the MasterProbe before you can do the "ref. sphere position" Link to comment Share on other sites More sharing options...
[To...] Posted October 5, 2018 Share Posted October 5, 2018 Please sign in to view this quote. Brian, based on the screenshot that Daniel posted, it doesn't appear this machine is capable of CAA so Fitting Position is not necessary. CAA is only available on TL-3 sensors. Anyway, the Ref Sphere Position must be done before the Fitting Position. Daniel, did you create a new machine tab, or did you create a backup of your config folder and use it to get your machine tab? Link to comment Share on other sites More sharing options...
[Da...] Posted October 8, 2018 Author Share Posted October 8, 2018 Finally I did manage to solve the problem. It took me fu*kin 3 hours. I did create a new machine tab and then pasted config folder. The solution was that I had to press "Yes" for "Update stylus". I pressed No and did not know that this can affect something later on. Anyway thanks for help. Link to comment Share on other sites More sharing options...
[To...] Posted October 8, 2018 Share Posted October 8, 2018 The plot thickens....It's a DuraMax.... I guess I should have figured that out from the 12.5 sphere radius. 😃 😃 😃 Link to comment Share on other sites More sharing options...
