[Ja...] Posted September 25, 2018 Share Posted September 25, 2018 Hello, My company just purchased a duramax CMM and it has the vast xxt head. I'll have more particulars later as it is still in the box. I am wondering how I get the probe info into the off line seat for the Vast XXT head. So I can program it offline as our CMM's are always tied up so programming real time is next to impossible. Right now all that is in the offline seat is the TP20 porbe head. I am also using Calypso 2016 Service Pack 5 for the offline seat Thanks Link to comment Share on other sites More sharing options...
[7c...] Posted September 25, 2018 Share Posted September 25, 2018 You will need to create a corresponding machine tab - Extras > Settings > CMM and add a Duramax with the XXT. Link to comment Share on other sites More sharing options...
[Ja...] Posted September 25, 2018 Author Share Posted September 25, 2018 how do I add the tab in? Right now it just says simulation Link to comment Share on other sites More sharing options...
[Ja...] Posted September 25, 2018 Share Posted September 25, 2018 You shouldn't have to add another tab, just define the one you have. First go to Extras/Settings/CMM/Machine and select the machine you'll be programming for from the pull down tab, and then make sure the Measuring Volume is correct. Next, click on the Probe tab and select Zeiss Fixed Mounting/XXT (assuming it's not an RDS). Link to comment Share on other sites More sharing options...
[To...] Posted September 25, 2018 Share Posted September 25, 2018 Here's something that I did a while backPlanner - Machine Set Up - RDS_VAST-XXT_10_17_2017.pdfPlanner - Machine Set Up - DuraMax.pdf Link to comment Share on other sites More sharing options...
[Ja...] Posted September 25, 2018 Share Posted September 25, 2018 Nicely done Tom. Link to comment Share on other sites More sharing options...
[Ja...] Posted September 26, 2018 Author Share Posted September 26, 2018 Thank you Tom, That worked! Much appreciated! Link to comment Share on other sites More sharing options...
[be...] Posted October 4, 2018 Share Posted October 4, 2018 Tom, do you have Planner setup for Accura 2 with Vast XXT RDS? thanks Link to comment Share on other sites More sharing options...
[To...] Posted October 4, 2018 Share Posted October 4, 2018 Hi Becky, It's identical to the RDS-XXT, except you'll select the Accura machine type. Link to comment Share on other sites More sharing options...
[be...] Posted October 4, 2018 Share Posted October 4, 2018 thank you Link to comment Share on other sites More sharing options...
