Saving Manual Input
Is there any way to put restrictions on saving manual input? Currently we have a report that combines both our CMM data and manual input. In order to save you must select "Write Changes". However, is there a way to make sure all the manual data is completed before the operator can move forward? Would appreciate any help thank you!
Im not sure if this is what you are trying to do, but here it goes.......
Say I have an ID that needs to be manually checked with a Deltronic pin after the CMM prg has ran. I toss in a Result Element as pictured below, double click it to open in the characteristic tab then enter all the needed info. After the prg has ran, the boxes will pop up prompting for the measurement to be entered manually. This will then be added to the report etc...
Again not sure if that's what you want to do...
  • 1 month later...
