Rack Assignments: Where are they stored?
Like the title states, where are the Rack Assignments stored?
How do I transfer/copy the assignment to another PC?
I have a program that has an assigned Rack configuration, when I try to run the program under "Subsequent Evaluation" the program fails due to not finding the required Rack Assignment.
(In the attached image, I Red Lighted the run, I could tell it wasn't going to calculate anything)
C:\\Users\Public\Public Documents\Calypso\Config is the folder you can copy to another computer and that should carry the Rack Assignments over with it.
The rack assignments are stored in a SQL database together with a lot of other probe related stuff. It's in the \config\equip\<machine_name> folder and the files are named sdodata.mdf and sdodata2.mdf. It is password protected however.
If a program fails because of a non-existent rack assignment, either make one with the same name or delete the name reference under Resources -> Measurement Plan -> Rack assignment.
  • 1 month later...
Unfortunately neither of the suggestions worked when using "Subsequent Evaluation".
It is odd how some .zmp files will run while others will fail.
