True Position Direction Question.
Hello,
How do I know which direction my Holes are out.
Example : TP of 5mm Bore to ABC at 0.050mm.
Result is 0.300mm
How do I find the direction that hole is moved? Is it based off of the Trihedrant (Probably spelt that wrong)
Thanks in advance.
Silvio,
I'm using Calypso 2018 so yours may be different.
Go to 'Resources', 'Characteristics Settings Editor', 'Additional Printout', click on 'Selected Features', highlight your true position(s), and set to 'On'. This will give you the actual values compared to nominal values. Make sure your nominal match the print.
