Point elimination
Activate if you measure close to the edge of the surface. When applying a best fit, the points might get translated/rotated so that some points are out of the surface boundaries. That can make the calculation slow. Turning it on, will eliminate all points that are out of boundaries, while keeping it off will still use those points for calculation.
https://qualityforum.zeiss.com/topic/20292-point-elimination/#findComment-114742
