[Ca...] Posted September 13, 2018 Share Posted September 13, 2018 I'm relatively new to Autorun. I've just run a batch of parts and I forgot to tick the box to use Custom Printout. Essentially, I've run a bunch of parts and I don't know how to display the reports for them. How can I display the Custom Printouts for the parts I've just run? Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/ Share on other sites More sharing options...
[Ri...] Posted September 13, 2018 Share Posted September 13, 2018 Unless you took steps to save these reports as Table files or Xcel spreadsheets, Calypso threw away, all but the last run. Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114872 Share on other sites More sharing options...
[Ca...] Posted September 13, 2018 Author Share Posted September 13, 2018 Looks like I'll have to run them again. Boooo! Thanks Richard! Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114874 Share on other sites More sharing options...
[Ri...] Posted September 13, 2018 Share Posted September 13, 2018 Turn Table files on before you do anything. Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114876 Share on other sites More sharing options...
[Ca...] Posted September 14, 2018 Author Share Posted September 14, 2018 Anyone care to give me a quick rundown on table files? I'll wade through the Caly help files in a moment. Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114878 Share on other sites More sharing options...
[Br...] Posted September 14, 2018 Share Posted September 14, 2018 If the measuring points are being saved, you can run a subsequent evaluation on the parts you have already ran to re-generate the reports. You might not be able to run a subsequent evaluation in autorun though, I'm not sure. Go to Plan>Subsequent evaluation, then click "Load Measurement points" then click "run". Regarding the table files, Go to Resources>Results to File. make sure the table file radio button is ticked "On". I would recommend making sure the measuring points option is on too so you can do subsequent evaluations. The table file will save text files to whatever path you have set up in your settings by the master user. Alternatively, you can set to go to a path that is exclusive to the measurement plan Resources>Name for output files. You can give it whatever nomenclature you want using variables such as your part number here as well which is really handy. Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114880 Share on other sites More sharing options...
[No...] Posted September 14, 2018 Share Posted September 14, 2018 You can't run a subsequent evaluation from Autorun, but from Calypso 2018 on you can evaluate several point files at once. Link to comment https://qualityforum.zeiss.com/topic/20314-autorun-reports-help/#findComment-114882 Share on other sites More sharing options...
