Autorun reports Help!
I'm relatively new to Autorun. I've just run a batch of parts and I forgot to tick the box to use Custom Printout. Essentially, I've run a bunch of parts and I don't know how to display the reports for them.
How can I display the Custom Printouts for the parts I've just run?
If the measuring points are being saved, you can run a subsequent evaluation on the parts you have already ran to re-generate the reports. You might not be able to run a subsequent evaluation in autorun though, I'm not sure. Go to Plan>Subsequent evaluation, then click "Load Measurement points" then click "run".
Regarding the table files, Go to Resources>Results to File. make sure the table file radio button is ticked "On". I would recommend making sure the measuring points option is on too so you can do subsequent evaluations. The table file will save text files to whatever path you have set up in your settings by the master user. Alternatively, you can set to go to a path that is exclusive to the measurement plan Resources>Name for output files. You can give it whatever nomenclature you want using variables such as your part number here as well which is really handy.
