[Te...] Posted September 10, 2018 Share Posted September 10, 2018 How would I correctly dimension this? I have a Plane for Datum A, a bore Ø for Datum B and 2 Pin Ø's that make up Datum C. I want a position to A and B but not sure if I need to separate them into two Ø's and make all the other positions to | A | B | C1-C2 | or if the Ø's treated as a pattern (2 x) is OK. I think it is but want to make sure. I was going to just use POS | Ø 0.1 MMC | A | B | is that enough or do I need to add a composite under it to restrain further? The 2 pins is what stop rotation and I think this would be enough. Any help would be greatly appreciated. Pardon the sketch I had to use WORD. 😃 All I want for Calypso is to use a 3d Line from the 2 Ø's for the planar rotation. Trying to get another Alignment out of the CAD Cube for training. 🙄 Position Question.JPGFetching info... Link to comment Share on other sites More sharing options...
[De...] Posted September 10, 2018 Share Posted September 10, 2018 If there is nothing else that you also need to use the C datum for, then POS | Ø 0.1 MMC | A | B 2 Places will work because they both have the same call out to the same datum reference frame with the same modifiers they are a simultaneous requirement so they basically become the datum. That said if you have other things that you want to also tie to the rotation provided by C then you might want to specifically define the C datum so that other features do not need to be considered when determining rotational location. Link to comment Share on other sites More sharing options...
[An...] Posted September 13, 2018 Share Posted September 13, 2018 _ Link to comment Share on other sites More sharing options...
[De...] Posted September 13, 2018 Share Posted September 13, 2018 On the original example, the two holes were centered on the datum Axis, on your example they are not, that makes all the difference. Link to comment Share on other sites More sharing options...
