Best fit bore pattern
I started programming on Virtual DMIS 18 yrs. ago. The way I was taught in VDMIS was to rotate to each hole, and report the X&Y deviations. I see Calypso has an option called "Best fit bore pattern" I have never used this option. Does it accomplish the same thing w/out the multiple rotations?
Here is a little tid-bit. I use this to output graphs for the machinist. You can turn off all rotation and translation. If you suck with numbers and can't read a cmm report, then you should atleast be able to look at a picture and tell if the pattern is good or not.
