"Results to File" How do I delete data reports?
Hi,
So I started using this feature with the 2018 update and PiWEB Reporting Plus. On the Measuring Points section, How Do I go in and delete a recorded result.
For example, If I run Part#5 and one feature was out .0001 due to dust, I would clean and re run as Part#5 and Overwrite the previous result. However, If I go into PiWEB Reporting Plus Software and want to do an eval of xx amount of parts, the original Part #5 that failed, is recorded in there.
How do I remove that data and where do I go to do that? I know I can individually select data but when you have a few that failed falsely and re ran, it a pain.
Thanks,
1. Open up Piweb to the report window as pictured here. You will have to hit F6 to get the complete menu as pictured. Click the icon I have outlined to get to the edit screen
2. Here double click on the ROOT PART that you want to change/delete/edit. Change things to your hearts desire. Hit the Save/OK and UPDATE ALL at the bottom and done. I do this all time as I have to manually pin ID's etc...
LOL double posted the same pic. Oh well disregard the middle one
OHH and you if you want to delete the whole run, highlight the entire row and hit the X button.
It will only show you the last 12 runs. There is a way to get 20 to show but I have not figured it out yet.....
To hide the first run, go to the same window Mike described. Select the part that you want to hide and at the top, select the icon with the red circle white line and block the measurement.
You'll also notice that a filter was already applied where Approve was not equal to blocked. So blocked means it will be filtered out.
I've never tried this but it looks logical.
