[Ru...] Posted August 24, 2018 Share Posted August 24, 2018 I think I may have came across another issue with Calypso 2018 and was wondering if anyone else has had the same experience? I ran a measurement plan through today. After it was done I changed the evaluation method on 1 bore that was inspected. Because it changed the diameter results I wanted to re-output the PiWeb results with the correct measurment. In the past I would uncheck the Clear existing results option in the Start Measurement window and click start. It would then go through the characteristics list and because all the actual where there it would skip to the end and output the PiWeb report. Today when I did this it restarted the entire measurement plan from the alignment. I thought I messed up so I stopped it, double checked that I had the Clear existing results unchecked, and started it again. The measurement plan is re-running everything from the characteristics list even though it had all the actuals from the first run. Once again I'm not sure if there is a setting that I'm missing that is defaulted on for 2018 that I normally hadn't had on or if this is an issue with 2018. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
[Si...] Posted August 24, 2018 Share Posted August 24, 2018 Interesting. I do the same with the Existing results. I do ot have 18, I have 17 and it does, at times, restart the measurement. I find that I does this with No CAD Model (manual mode). Also, perhaps it is because of the Eval change it wants to re measure. Try just running that characteristic alone if it keeps happening. Link to comment Share on other sites More sharing options...
[Ra...] Posted August 27, 2018 Share Posted August 27, 2018 Does Calypso exhibit the same behavior when using "Subsequent Evaluation" for re-generating a report? Or, do you find this only by re-running and not clearing the existing data? Just curious; we're days away from the upgrade. Link to comment Share on other sites More sharing options...
