[Pa...] Posted August 8, 2018 Share Posted August 8, 2018 When running parts via Autorun, a ‘CNC manual’ window randomly opens after some measurement plans have finished running. I believe that the measurement plan is reloaded when this appears. Any external PCM files named ‘inspection_start_pcm’ are also executed automatically when this appears (this causes problems for us). As I mentioned, the window appears randomly (not after every run). It happens on multiple machines, and after several different measurement plans. We are running CALYPSO 2015 , ServicePack 2, Version 6.0.08 (09.10.2015). Can anyone tell me what causes this and how to prevent it from happening? Link to comment Share on other sites More sharing options...
[Cl...] Posted August 8, 2018 Share Posted August 8, 2018 I have autorun running on all our machines, and have never seen this before? Link to comment Share on other sites More sharing options...
[Pa...] Posted August 9, 2018 Author Share Posted August 9, 2018 Nobody has seen this window before? We see this on all three of our CMMs... Link to comment Share on other sites More sharing options...
[An...] Posted August 10, 2018 Share Posted August 10, 2018 I work a lot in autorun, but I've never seen this message! Link to comment Share on other sites More sharing options...
[Ri...] Posted August 10, 2018 Share Posted August 10, 2018 I have never seen this screen. You described it's behavior as random, not every run. And you said that it involves several different programs. Is it always occuring with the same programs or is that random as well? Link to comment Share on other sites More sharing options...
[Ri...] Posted August 13, 2018 Share Posted August 13, 2018 Also, could you post the inspection_start_pcm.txt file? Link to comment Share on other sites More sharing options...
[Pa...] Posted August 14, 2018 Author Share Posted August 14, 2018 Richard, the window shows up randomly after a run in Autorun for any of our programs. inspection_start_pcm.txt: ————————————————————- chr_Side1=getRESULTS()+”\Side1__chr.txt” fet_Side1=getRESULTS()+”\Side1__fet.txt” hdr_Side1=getRESULTS()+”\Side1__hdr.txt” if fileExists(chr_Side1) then deleteFile(chr_Side1) endif if fileExists(fet_Side1) then deleteFile(fet_Side1) endif if fileExists(hdr_Side1) then deleteFile(hdr_Side1) endif clearParameter(“chr_Side1”,”fet_Side1”,”hdr_Side1”) ———————————————————————— (Window shows up after programs with absolutely no PCM code as well.) Link to comment Share on other sites More sharing options...
[Ri...] Posted August 15, 2018 Share Posted August 15, 2018 Paul, does this only occur in the Autorun environment or have you ever seen this when running Calypso without Autorun? Link to comment Share on other sites More sharing options...
[Ow...] Posted August 15, 2018 Share Posted August 15, 2018 I have no idea but, it kind of looks like the "Point Program" interface found in the stoplights task-bar, located under the " more" menu. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 15, 2018 Share Posted August 15, 2018 I have been working with a German friend of mine on this. Owen, I think has provided a valuable clue. Paul, what kinds of machines do you have Calypso running on? Link to comment Share on other sites More sharing options...
[Pa...] Posted August 16, 2018 Author Share Posted August 16, 2018 We have Contura G2, Prismo Navigator, and Accura CMMs. This only occurs when running programs from Autorun. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 20, 2018 Share Posted August 20, 2018 If the behavior only occurs when you use Autorun, then the first thing I would try is to build a new .arn file with a single part program that you know was running when the problem occured. Test that and if the problem disappears, add another program and test that. If the problem shows up, then you can look at the program. There's a trigger someplace that's getting pulled, sometimes. Link to comment Share on other sites More sharing options...
