[Do...] Posted August 16, 2018 Share Posted August 16, 2018 When I go to get a circle on cylinder on my CAD it actually grabs a radius thru the CAD instead of on the outside. I am running Calypso 6.4 and have recently upgraded to windows 10. Not sure if this has something to do with it or not, I have tested this same CAD model on windows 7 and it worked fine. Is there some settings I'm missing or something in windows 10 or Calypso 6.4? Link to comment Share on other sites More sharing options...
[Me...] Posted August 17, 2018 Share Posted August 17, 2018 I haven't had this problem yet, and I am on 6.4 and Windows 7, cause ....Windows 10.....yeah anyways. So I'll go for the easy answers, and maybe to try Cad->Cadfile->automatic healing. Either that or maybe it is Windows 10, because I would love to blame it all day. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 17, 2018 Share Posted August 17, 2018 I would be interested to see what happens if you pick a space point on that same surface, which direction does the vector point? Possible some sort of vector error that healing could correct? Is the circle you are trying for an OD? Is the one you get the same (OD) Or are you going for an OD, and getting an ID. Link to comment Share on other sites More sharing options...
[a8...] Posted August 17, 2018 Share Posted August 17, 2018 I would check your graphics card settings. Make sure that you have them set to High Performance. I can't speak to every card but I'm using an AMD Radeon and I had to manually go into the settings and ensure Calypso permissions were set to High Performance. This eliminated my click-through CAD issues. Link to comment Share on other sites More sharing options...
[Ma...] Posted August 20, 2018 Share Posted August 20, 2018 Please sign in to view this quote. +1 Link to comment Share on other sites More sharing options...
[Da...] Posted August 20, 2018 Share Posted August 20, 2018 Can some confirm what Josh recommends here? -> viewtopic.php?f=13&t=450&start=10&hilit=nvidia Is there anything else to set?nvidia-settings2.PNGnvidia-settings2.PNGnvidia-settings.PNGnvidia-settings.PNG Link to comment Share on other sites More sharing options...
