Curve Form report
I cant seem to come up with why the curve form shows this curve shifter in -Y by 0.2488mm but when I construct a line from center and intersect this circle then measure to the intersection, I only get off by 0.14mm.
The number on the bottom of the curve form plot is the distance from nominal correct? Please also see the attached PDF.
distance12.jpgLobe12.pdf
While troubleshooting this I measured the circle using the radius measurement (which locks center at the 63.668) and it shows the worst deviation is -0.14 (diff)
But then I shifted the nom on the curve down in -Y by 0.2488 and the plot shows it almost on nominal. This is confusing and doesn't jive.
Any thoughts?
